Message 1 of 3
Sky q box and br hub won’t now accept password
Hi my home hub dropped out,it restarted but now my Sky q box won’t now take the hubs password? Tried everything,can any one help please. Thankyou.
2 REPLIES 2
Message 2 of 3
Re: Sky q box and br hub won’t now accept password
Mine does that now and then, I find if you switch of the hub, then switch off the Sky Q box, then switch on the BT hub and wait for it to connect and turn blue, after that switch the Sky Q box back on, normally it will connect automatically, if not enter the wi-fi password again.
It's always on the Sky Q that does it, no other devices but it doesn't happen often so not too annoying.
Message 3 of 3
Thanks I will try that.
