Message 11 of 18
Re: Slow and very intermittent wifi
found it 🙂
Message 12 of 18
Are you sure it is actual WiFi link speed that is slow or throughput that is slow? You should be able to see the link speed on a connected device.
Message 13 of 18
Thank you - i have problems in the speed to my ipad/iphone devices most of the time but the laptops are always faster when i do a speed test on them. i stand in front of the router for all so its not distance or walls.
Message 14 of 18
i tried various channels and modes and the results were similar.  i then went back to the reset to recommended - still similar.  i then switched off the 5GHZ and at the moment and its probably just a fluke but everything is working at the same speed - laptop/ipad/iphone each being tested on a speed  test and all good.  no idea why or if it will last
Message 15 of 18
But have you checked the wifi link speed rather than download speed via a speedtest site.
Not sure where you would find it on Apple devices but it will be in network settings somewhere.
The link speed is the actual speed of the wifi connection between the hub and device. Mine is below, the link speed is 866Mbs but throughput will be far less as I only have a 40Mbs broadband connection.
Message 16 of 18
thank you for your help and advice. I am still getting 20Mb speeds (which for my location is the best ) after switching off the 5GHZ channel. i am now getting the same speed on both the lap tops and ipads when testing. I will keep all my fingers crossed that this keeps working and either way will come back on and advise you. many will laugh at the sheer joy of getting 20mb solid but believe me i am a happy person at the moment 🙂
Message 17 of 18
Final message.  Thank you for the help and advice.  My nightmare of no wifi and very slow wifi for ever was solved by switching off the 5ghz channel.  I did this by chance and it worked.  Looking into this more I suspect the problem was some devices needed to get on the 2.4 ghz channel but could not as the 5ghz was on.  I am guessing they flooded the network and the clashes caused the outages and very slow speed. Switching off 5ghz allowed them to connect and stopped the problem.  This maybe utter BS but that’s the best I can come up with. So happy at 20 mb speed and anyone who has higher speeds than this should be happy.  Ps glad I joined this community
Message 18 of 18
Glad you got it sorted. The more likely cause is a faulty 5Ghz module in the hub and devices favouring it over 2.4Ghz.  The 2.4Ghz signal is slower than 5Ghz but has greater distance. You don't need the extra speed of 5Ghz as your limiting factor is your broadband sync speed.
