Message 31 of 34
Re: Slow / long Youtube load/seek times
Seems fine now, is it a permanent fix though?
Message 32 of 34
Hi @csiwek and @ST7, thanks for checking that and posting back. The fix should resolve the issue permanently but do let us know if you encounter any issues and we'll be happy to help.
Cheers
John
Message 33 of 34
Heya, I've been following this post and I've consistently had these issues since joining as well - but with both YouTube and Google. And the issue is still ongoing.
I've opened a separate ticket for this due to the Google element and also because this shouldn't be marked as 'Solved' just yet. I've referred back to this thread in the post also.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Very-slow-YouTube-and-Google-loading-speeds-and...
Message 34 of 34
I still have this problem does anyone think it may be due to BT Web Protect as it seems to be the ads that slow any loading. I'll switch it off and see if it removes the problems
