Message 21 of 34
Re: Slow / long Youtube load/seek times
it seems ok now. let's hope it's permanent this time 🙂
Message 22 of 34
Hi @csiwek
Thank you for posting back.
Sorry again that this issue reoccurred. I am pleased to see it's working ok.
If you need a hand in future you know where we are.
Take care.
Robbie
Message 23 of 34
it happens again:
ping rr4---sn-cu-ajted.googlevideo.com -s 1400
--- rr4.sn-cu-ajted.googlevideo.com ping statistics ---
29 packets transmitted, 12 received, 58.6207% packet loss, time 28327ms
rtt min/avg/max/mdev = 3.136/3.641/3.893/0.255 ms
Message 24 of 34
Thank you @csiwek. I am sorry that you experienced it again.
@ST7 did you notice any changes yesterday or again today?
Dan
Message 25 of 34
Seems fine at the moment, everything loading straight away, can't remember yesterday to be honest.
Message 26 of 34
Thank you @ST7.
I was on it last night too but didn't come across any issues.
If this continues to happen to either of you over the weekend, can you post up here and I'll contact the team again?
DanielS
Message 27 of 34
Hi @RobbieMac and @DanielS
First of all, thanks for the support.
I am not home at the moment but I can SSH there and I can confirm that the packet loss to that address still occurs.
Interestingly,  It only happens when pinging over IPv4.   IPv6 is just fine.
please see the results:
csiwek@server:~$ ping rr4---sn-cu-ajted.googlevideo.com -s 1400
PING rr4---sn-cu-ajted.googlevideo.com(2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f)) 1400 data bytes
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=1 ttl=61 time=3.27 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=2 ttl=61 time=3.22 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=3 ttl=61 time=2.98 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=4 ttl=61 time=4.51 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=5 ttl=61 time=4.47 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=6 ttl=61 time=3.57 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=7 ttl=61 time=3.73 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=8 ttl=61 time=3.63 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=9 ttl=61 time=3.35 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=10 ttl=61 time=3.56 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=11 ttl=61 time=3.70 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=12 ttl=61 time=3.11 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=13 ttl=61 time=2.75 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=14 ttl=61 time=2.73 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=15 ttl=61 time=4.25 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=16 ttl=61 time=4.36 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=17 ttl=61 time=4.37 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=18 ttl=61 time=4.37 ms
1408 bytes from 2a00:23a0:1e5:5::f (2a00:23a0:1e5:5::f): icmp_seq=19 ttl=61 time=2.83 ms
^C
--- rr4---sn-cu-ajted.googlevideo.com ping statistics ---
19 packets transmitted, 19 received, 0% packet loss, time 18028ms
rtt min/avg/max/mdev = 2.731/3.618/4.508/0.598 ms
csiwek@server:~$ ping rr4---sn-cu-ajted.googlevideo.com -s 1400 -4
PING (213.123.245.175) 1400(1428) bytes of data.
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=1 ttl=124 time=2.51 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=2 ttl=124 time=3.88 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=4 ttl=124 time=3.26 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=5 ttl=124 time=2.97 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=6 ttl=124 time=2.61 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=7 ttl=124 time=3.91 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=11 ttl=124 time=3.18 ms
1408 bytes from host213-123-245-175.in-addr.btopenworld.com (213.123.245.175): icmp_seq=12 ttl=124 time=2.83 ms
^C
--- ping statistics ---
13 packets transmitted, 8 received, 38.4615% packet loss, time 12089ms
rtt min/avg/max/mdev = 2.513/3.144/3.907/0.493 ms
Message 28 of 34
I'm encountering it on some but not all youtube pages, now.
Message 29 of 34
Hi @ST7 and @csiwek, thanks for posting back and sorry you're still seeing this issue.
The team has made a change and tested and they're not seeing packet loss now. Please would you check again and let us know how you get on?
Cheers
John
Message 30 of 34
I can confirm I don't see the packet loss anymore... I'll do more tests when I'm back home next week
