Message 1 of 7
Smart Hub 2 & USB Connection via Linux
Can anyone help?
I have a USB connected hard drive on my Smart Hub 2 which I have mapped and accessed successfully with Windows 7&11.
However, I'm having no success mapping the same USB hard drive using Linux. In part, this is due to not knowing or having the Smart Hub root password or user name - using the provided Admin password for the Hub Manager alone does not to work. My previous 3rd party router worked successfully with all OS's.
I am using cif-utils software to make the connection but the response is always refused for the lack of user name/passwd. Any advice to overcome this hurdle would be most welcome - thanks.
6 REPLIES 6
Message 2 of 7
Re: Smart Hub 2 & USB Connection via Linux
You don't need a username and password to access the USB port on the Smart Hub.
The port is only enabled for SMB1
Message 3 of 7
Just connected fine from my Raspberry Pi using anonymous login via smb://192.168.1.254/usb1
Message 4 of 7
Thank you for your confirmation that an anonymous connection can be made, as is the case thru' Windows, but that continues to defeat me even trying your solution from my Pi. Perhaps you would explain how I should complete the type (I've assumed FTP to date), host & path boxes on the "Connect to Server" utility to achieve success?
Clearly I am missing a trick as I keep getting asked for a password. Do I first have to mount the target in fstab, perhaps?
Message 5 of 7
Just navigated to it via file manager
Message 6 of 7
Must be finger trouble here - solved. Many thanks.
Message 7 of 7
This has been going on for years. SMB1 is disabled by default by Windows because it is a security risk. The BT Home Hub is an up to date piece of equipment and should not rely on this outdated protocol. I have seen emails going back for 4-5 years about this. Can it please be sorted by a firmware update allowing the Hub to use SMB3?
