Message 21 of 43
Re: Smart Hub 2 and Bridge Mode
A password isn't actually required and can be anything, but some routers require an entry rather than blank.
Message 22 of 43
ok thank you
Message 23 of 43
Oh well that didnt work, I must have done something else wrong
BT Business Smart Hub is defiantly in bridge mode lights are orange
ticked requires user put in user name ([email protected] ) and random password(and tried blank)
doesnt seem to be getting an IP address from BT
Message 24 of 43
Is the VLAN set to 101 on the hub?
The HG612 would have been plug and play.
Are you sure you have set the Orbi to PPPoE and not DHCP?
Message 25 of 43
Vlan yes
whats HG612?
yes I'm going to reset all and try again in a couple of hours, thanks for the replies
Message 26 of 43
The modem I recommended in message 4!
Message 27 of 43
Ok so finally sorted, tou need to put in your own user name not the generic one and i didnt need to set the Vlan
Thanks for.pointing me in the right dieection
Message 28 of 43
Not sure how you got it to work, you won't have your own PPPoE username unless you have business account.
Message 29 of 43
Me neither, he did ask whether I was Business or residential, told him residential
Message 30 of 43
OK, the username is generic as anything before the @btbroadband.com can be used. I suspect it is just coincidence it worked when you used your first name,last name instead of the usual bthomehub.
If you are using the PPPoA settings, you must have standard ADSL broadband rather than FTTC VDSL broadband which is why PPPoE didn't work.
