Message 1 of 2
Smart Hub 2
Hi, I've just received a SH2 as part of their forced DV Rollout and have multiple issues which I'll address one at a time.
If I rename the SH2 WiFi SSID's to be the same as my existing hub, can I change the SSID's password to be the same too.
If so, I assume I'll have to switch my existing WiFi's before enabling the SH2 WiFi.
I don't fancy having to go round all my devices and type in new SSID's and passwords. ( 20+ )
1 REPLY 1
Message 2 of 2
Re: Smart Hub 2
You can change the hub SSID and WiFi password to that of previous router and save having to change all your WiFi devices.  I do this every time .
I just plug new router in without connecting to internet and connect to new router with ethernet and then make the changes and that way it is ready to go when connected to internet
