Message 1 of 6
Smart Hub Configuration
I note that within the Smart hub settings Access Control is via the My BT app.
However within the app it seems that access control is applied at device level and not at hub level.  I want to block particular domains or websites at particular times.
Can this be done for the Smart Hub?
5 REPLIES 5
Message 2 of 6
Re: Smart Hub Configuration
No
Message 3 of 6
So it really ought to be called the Nearly or Not So Smart Hub?
Message 4 of 6
Youre looking for too much from an ISP Router, the SH is smart enough.
If you would like granular network wide restrictions to be applied you will need a 3rd party device, you can get routers where you can do this sort of thing.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 5 of 6
OK, so it's the Smart Enough (but not that smart) Hub?
Message 6 of 6
Whatever.
