Message 1 of 23
Re: Purple flashing light
I use the BT smart home as an access point, is there a way to disable this flashing purple light? Because now its always blinking.
22 REPLIES 22
Message 2 of 23
Put a piece of black insulation tape over it.
Message 3 of 23
Really there isn't a way or option to disable it?
Message 4 of 23
No
Message 5 of 23
Im having deja vu….
Do you reckon you could achieve a solid orange or red light by taking a patch cable and hooking up the assigned WAN port to one of the LAN ports?
Could be more desirable.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 6 of 23
I think it is possible to find a creative way to keep the light solid in such a situation. Can you explain more about your idea? There is no WAN port in BT Hub6.
Message 7 of 23
The idea (which might not work anyway), is only applicable to the Smart Hub2 where LAN port 4 can be configured as a WAN port for FTTP.
Message 8 of 23
Is there any guidance for this?
Message 9 of 23
Any guidance for what?
Message 10 of 23
For configure LAN port 4 as a WAN port
