Message 1 of 5
Smart Hub Plus
Hello like otherr posts I am moving to EE and I am not retaining my Phone number
I have a Smart Hub in bridging mode with a Orbi Router and WiFi network
Does the Smart Hub Plus have bridging mode?
4 REPLIES 4
Message 2 of 5
Re: Smart Hub Plus
No BT residential hubs have a bridge mode, you must have a business hub.
I doubt EE residential hubs have a bridge mode but as you don't require telephony, you don't need to use an EE hub anyway. Just connect the Orbi directly.
Message 3 of 5
Re: Smart Hub Plus
Hello Thanks for the reply
Sorry if I am being a bit thick but how do I do that my wall socket is RJ45 and I only have CAT5 connections on the Orbi
Message 4 of 5
Re: Smart Hub Plus
I was assuming you had FTTP rather than FTTC.
I think you should be able to continue using your BT hub as now.
Message 5 of 5
Re: Smart Hub Plus
Ah ok thank you
