Message 1 of 12
Smart hub 2 and NoIP DDNS
I have  a BT  Smart Hub 2  and want to use  NoIP DDNS .
I have set up a NoIP account with a password alpha numeric , lower  case  no special characters .
I have set up NoIP in the DDNS page  on my Smart Hub 2  , double checking that all the details are  correct but it still shows an Error  ..... " Host Name Not Recognised "   its a ddns.net  host name so should work  but it doesnt .
I tried phoning BT but they didnt have a clue what I was talking about !!!!
Anyone on here who can help me solve the problem please .
11 REPLIES 11
Message 2 of 12
@ Smart Hub 2 and NoIP DDNS " Hostname error "
I have set up NoIP in the DDNS page  on my Smart Hub 2  , double checking that all the details are  correct but the Smart hub DDNS page  still shows an Error  ..... " Host Name Not Recognised "   its a ddns.net  host name so should work  but it doesnt .
Message 3 of 12
Re: @ Smart Hub 2 and NoIP DDNS " Hostname error "
Please do not post the same question across multiple boards. It only causes confusion and duplication of answers should you get any.
Message 4 of 12
Re: Smart hub 2 and NoIP DDNS
'It' being what? The hub, or something else.
Message 5 of 12
' It' being the BT Smart HUB 2  !
Message 6 of 12
Not used this before , can you Help with my question ????
Message 7 of 12
No need for the exclamation mark, 'it' could have been anything. You need to be precise.
Did you select 'Dynamic DNS as 'On' and then 'Save' before trying to configure the service?
It works just fine for me.
Message 8 of 12
Message 9 of 12
Thank you .
Those  are the  settings  I am using  ( apart from first part being different of course ) ,
But the Hub still shows an error " Host name not recognised "
Message 10 of 12
Dynamic DNS is set to " ON"  and I clicked save  but the smart hub 2  still will not accept the hostname
