Message 1 of 29
Smarthub 2 disconnecting
Over the past 2 weeks my Smarthub 2 keeps disconnecting and reconnecting.  I contacted BT 4 days ago and they refreshed the line.  Still same problem.  I have turned the hub off and on again but still same problem.  I also have 4 black wi-fi discs around my house.  Can anyone help me as BT are not providing me with a solution!
28 REPLIES 28
Message 2 of 29
Re: Smarthub 2 disconnecting
as long as you don't have digital voice can you check for line noise on your phone by dialing 17070 option 2  should be silent and best with corded phone
Message 3 of 29
There is a slight crackle on my land line but when I make calls the crackle is worse.  I have had many BT and Openreach engineers I think I have had around 15 visits in this year alone, but they can never find a fault on the line.  It's most infuriating!
Message 4 of 29
sorry but you need to report a phone fault not a broadband fault to 151 or 0800800151 from mobile
if you can get line fixed and no crackle then you should get a stable connection
Message 5 of 29
I had an engineer last week regarding crackle on line and they couldn't find a fault!
Message 6 of 29
I reported phone fault many times, BT engineers have been sent but they can't find a fault on the line!
Message 7 of 29
Hi @andreaferns120472
Thanks for your posts and welcome back!
I am sorry for the problems you're having with noise on your line when you're making calls.  This would also affect your broadband service.  I am disappointed to see that you've had to book so many engineer visits that haven't been able to repair the fault.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 8 of 29
BT Smarthub2
Can anyone recommend an alternative to the BT Smarthub 2 router. My Smarthub keeps disconnecting and I have read in community to try a different router
Message 9 of 29
Re: BT Smarthub2
@andreaferns120472
What broadband package do you have, and are you on BT Digital Voice?
Message 10 of 29
Re: BT Smarthub2
My broadband package is Fibre with Halo 3, not sure what you mean by BT Digital Voice?
