Message 11 of 13
Re: Smarthub 2 password hacked and changed by outside actor - what now?
@licquorice wrote:
If you connect via Ethernet you don't need a password to access the basic menu.
Sorry @WSH , that was meant for @Fiigural  to try.
Message 12 of 13
Ah, sorry.
Message 13 of 13
Just a little nudge, that if look at the card on the router that have the passwords on, the admin password is not the same as the network password.  So even if someone cracks your WiFi password they would still have to crack the admin password.  Cracking admin passwords should be exceptionally difficult as any decent router should limit the number of attempts in any time frame.
And in most cases, unless you've disabled it, then WPS should still work!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
