Message 1 of 8
Some devices connect with no internet
My Android devices and Kindles will connect to the Hub no problem but I get the message "Connected(no internet access". Rebooting the hub (we're on our 3rd with the same problem) connects them with internet but a few hours later, the problem recurs. Rebooting the devices themselves has no effect. They are on 5 GHz by the way. Thanks.
7 REPLIES 7
Message 2 of 8
Re: Some devices connect with no internet
Incidentally, it happens whether I connect to the Hub or the Disc.
Message 3 of 8
First factory reset the hub ( not just reboot) to clear out any stale entries and the turn off MAC randomisation on your devices to prevent the DHCP table filling up again.
Message 4 of 8
Thanks for your reply. It's a brand new router, so there shouldn't be any stale entries (I've checked the hub). There is  no setting to turn off MAC randomisation on either our Honor devices (2 phones, 2 tablets) or our Kindles. Is it all about "trusted devices"? I'm a bit stuck.
Message 5 of 8
I would still factory reset it. The stale connections won't be visible in the hub manager.
Message 6 of 8
The most common reason for what's being described is using a second router as a network switch but not turning off its DHCP server—could that be the case here?
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 7 of 8
No, that isn't the case. I have factory reset the hub by the way, I'll see how it behaves tomorrow - a pain to connect everything, yet again!
Message 8 of 8
Not sure why it's a pain, unless you have changed anything from default everything should just reconnect.
