Message 1 of 3
Sudden lose of connection
My hub's light signal has randomly turned orange and I lost connection to the Internet. After a few attempts of checking cables and restarting the hub, the light remained pink and kept on blinking. I believe there are no issues with the cables neither the hub. Any solutions?
2 REPLIES 2
Message 2 of 3
Re: Sudden lose of connection
Have you considered reporting the fault to BT?0330 1234 150
Message 3 of 3
If the hub light is pink (purple?) and flashing, it means that that the cable (copper for FTTC, fibre for FTTP) has become disconnected or severed somewhere - more likely outside your house.
As licquorice suggests, you need to report this as a fault to BT. You can do this via the number shown or online at:
www.bt.com/exp/engineer-booking
