Message 1 of 14
Switching from BT Router to TP-LINK Issue,
Hi,
So I want to switch from BT to TP Link and after setting everything up, changing connection type to PPPoE with login  [email protected] and BT password but I'm getting an error message saying that the ethereal cable is not connected, can any advise how to resolve the issue?
13 REPLIES 13
Anonymous
Not applicable
Message 2 of 14
Re: Switching from BT Router to TP-LINK Issue,
What service do you have, what model router do you have & where are you seeing the message?
Message 3 of 14
Getting that error in the TPlink app, and Im using that router : TP-Link Next-Gen Wi-Fi 6 AX5400
Message 4 of 14
@zoom91
You need to edit out that link, as its not permitted on this forum.
That router only works with full fibre, or a separate modem.
Message 5 of 14
Any suggestions for different router?
Message 6 of 14
You need to answer the question about what sort of Internet connection you have. Also, why are you not using the BT home hub that has been provided?
Message 7 of 14
got Fibre with BT Halo 1 and need better WIFI
Message 8 of 14
you need to be more specific - is your connection fibre to cabinet and copper to your home FTTC or fibre direct to your house FTTP and connects to ONT like this
Message 9 of 14
Do you mean fibre 1, which is a copper connection to the home hub?
What speed do you normally get if you are connected to the home hub, using an Ethernet cable?
Message 10 of 14
dont have that one so I guess it's not fibre optic,
