Message 1 of 6
Third Party Modem / Router - Download speeds decimated but upload speed normal
I have tried to swap out the BT residential Smart hub 2 with a Zyxel VMG1312-T20B Modem in Bridge mode and a TP-Link AX3000 Router ( also tried using the Zyxel as the Modem + Router to same result ) but when I do my download speed is reduced from ~38Mbps to ~1Mbps yet my upload speed is normal ( 9 Mbps )
Can't tell where I am going wrong here I have a FTTC line and ethernet cabled from router to PC, VLAN ID is set to 101, PPPoE creds is [email protected] / BT, RJ11 cable going from the master socket 5c to modem
For simplicity sakes I tried disconnecting the TP-Link router and using the Zyxel as both Modem + Router
WAN Interface Settings:
Strangely from the Zyxel Web GUI I can see expected speeds showing up on the DSL input line:
DSL information for good measure:
xDSLFwVersion: FwVer:5.10.6.0_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.INP) DS ONLY
Annex Mode: ANNEX_B
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 0 kbps
near-end fast channel bit rate: 39999 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 9994 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 0
near-end CRC error fast: 0
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 5
far-end FEC error interleaved: 0
far-end CRC error fast: 1
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime :25 min, 31 secs
DSL activetime :0 min, 19 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 11.2 dB
output power upstream: 0.9 dbm
attenuation downstream: 8.8 dB
Upstream:
noise margin upstream: 10.2 dB
output power downstream: 0.8 dbm
attenuation upstream: 0.1 dB
Anything different I could try here setup wise? as soon as I reconnect Smart Hub I get back the usual speeds ( 38 Down / 9 Up )
5 REPLIES 5
Message 2 of 6
Re: Third Party Modem / Router - Download speeds decimated but upload speed normal
try [email protected]
Message 3 of 6
Sorry that was a typo, I was using [email protected]
Message 4 of 6
@danhawes
So have you corrected the entry in your router?
Message 5 of 6
your router stats shows [email protected] not btbroadband .com
Message 6 of 6
Sorry In my haste to recreate the settings after a factory reset in order to make this post I mistyped this field.
Originally and currently I have set the username to bthomehub@btbroadband .com
Tags (1)
