Message 1 of 5
Connect direct to ONT?
This page Openreach modem (ONT) explained: Ports and models available | BT Help   implies I could continue using my modem with an ONT.  I don't really want a Smart Hub (I was sent one two years ago) as I connect my Deco mesh via PPPoE to the modem.  I guess I would need the SH if I wanted DV.
Or have I misunderstood?
4 REPLIES 4
Message 2 of 5
Re: Connect direct to ONT?
When you say modem, do you mean router? The ONT is a modem, you can connect any PPPoE capable router to it, not another modem. However, you will not have access to Digital Voice.
Message 3 of 5
@licquorice
Thanks.
I use an old HG612 modem now and then connect my Deco M5 mesh to that under PPPoE.  I don't use a router.  So, if we ever get fibre I could continue as now.  I was slightly puzzled that no one ever seems to mention doing this.
As I am old, I still like  proper telephones so DV with an adapter may be needed but I will cross that bridge if/when OR arrive here.  Meanwhile CF/Zen is at my front door.
Last hurdle on leaving BT would be getting a new non-openworld email address.
Message 4 of 5
The Deco M5 is a router.
But yes you could connect the M5 directly to the ONT and it probably would not need any changes made to the configuration.
Message 5 of 5
As @dave44 says, the Deco is a router, just connect it to the ONT instead of the Hg612.
