Message 1 of 5
Unbreakable WiFi and Ethernet
Hi Guys,
I have just taken out Fiber 2, Complete WIFI and the EE hub thing to make my WIFI Unbreakable.
So, I use my PC for gaming and work, so usually connect via Ethernet. Will my PC keep it's connection if I use an ethernet connection, or is the "unbreakable" part only workable with WIFI connected devices?
Thanks In Advance
4 REPLIES 4
Message 2 of 5
Re: Unbreakable WiFi and Ethernet
the unbreakable refers to hub dropping internet connection and if that happens then hybrid connect cuts in and enables to to maintain internet connection
Message 3 of 5
Thankyou for your reply.
So, if I am connected with an Ethernet cable, it’ll still connect when the broadband drops and mobile router kicks in?
Message 4 of 5
yes if you hub drops connection then hybrid connect should maintain your ethernet internet connection
Message 5 of 5
so if the laptop is connected via ethernet cable to the router and the router to BT connection fails, then the Router connects to the EE box and connects that way ?
Or does the laptop need the wifi enabled so when the cable connection via the router fails, the laptop can connect to the EE box via its wifi to reconnect.
