Message 1 of 13
Upload Speed on third party router
Hi all
I have recently changed my router to a tp-link AX5400 after following the various instructions on the forums about connecting it directly to the ONS and putting it in PPPOe the wifi speeds are now much better. However, when I am wired my download is still 900 Mpbs but upload is only 0.55 Mpbs, have I missed something?
12 REPLIES 12
Message 2 of 13
Re: Upload Speed on third party router
No idea, but its a problem with the Tp Link if speeds are OK on wifi but not Ethernet.
Message 3 of 13
If you can try from a different wired device - should that work just fine then it's likely to be the network settings on the first device that need looking at.  The most common cause is that at some point they've been set manually and worked just fine, but they're now not working with some settings difference with the new router.  As an example using DHCP your TP-Link router probably sets the gateway as 192.168.1.1 while on the SH2 I believe it's 192.168.1.254
Should that be the case a DHCP set client will adapt correctly but a client with the network settings set manually wouldn't!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 4 of 13
You are correct, I have wired on another laptop and both download and upload are fine. What do I need to do to my PCs connection to reset it?
Message 5 of 13
Settings > Network and Internet > Advanced Network settings > Select your Ethernet adapter and disable it, then enable it.
Message 6 of 13
Tried that, still the same. Also tried a different RJ45
Message 7 of 13
The upload speed is fine on PC if I switch to wifi instead of wired. As soon as I go back to wired it upload is shocking. I am very confused?!
Message 8 of 13
Just to clarify,
upload speed is ok on laptop1 wifi but not Ethernet if using TP Link router
upload speed is ok on laptop2 wifi and Ethernet if using TP Link router.
Is upload speed ok on laptop 1 wifi and Ethernet if using BT hub?
Message 9 of 13
Hi licquorice
That is correct, I had no problems with upload on anything with the BT Hub
Message 10 of 13
Rather than just disabling and enabling the network adaptor try resetting it. This will uninstall and reinstall the network adaptor etc back to the default settings.
Go to settings > Network & Internet settings > scroll down and click on Network Reset > Reset Now.
