Message 21 of 30
Re: Used BT Smart Hub 2
£27 seems a lot of money just to play with a hub manager that is severely locked down and very little different from the Hub6. Your money, your choice.
If you only want it to play with the hub manager, don't connect it to line then BT will definitely be unaware you have it.
Anonymous
Not applicable
Message 22 of 30
IIRC from other threads, the OP is, or at least was, running a HH3, so an upgrade probably due! But SH2s seem readily available from Facebook Marketplace for a tenner or less.
Message 23 of 30
Yes, not connected so precisely, my choice.
Message 24 of 30
As already stated, BT knows what router you are running, and quite frankly I'm sure they don't care lol ! If you're happy then so are they...
Message 25 of 30
I think you are missing the point, the OP doesn't want to prejudice being sent a new SH2 when moved to DV.
Message 26 of 30
I get it !
Message 27 of 30
But I don't want to be running an old SH2 if this would jeopardise me getting the latest iteration of that Hub when the DV changeover happens. I want to be sent the latest one from BT with latest firmware etc etc.
Message 28 of 30
There is no 'latest' SH2, they are all the same. The firmware is automatically updated online and will always be the latest version.
Message 29 of 30
BT would send a free (loan) one if DV is compulsory.
I suspect a lot of ones that are for sale, have been "stolen" from BT, as they are only loaned, unless they had been purchased retail, or on a very old contract.
Some of the sellers may find that they get a request to return the SH2 or get charged, if they move ISP.
Message 30 of 30
Thanks guys. I will try and leave it there.
