Message 1 of 2
WAN IP Passthrough with bridge mode help
Hi,
I recently got a Unifi UDR router and am starting to tinker with networking stuff. My smart hub 3 is set to bridge mode. But the WAN IP being passed to my UDR router is a private IP address given out via DHCP from the smart hub. I want the smart hub to work completely transparently and just give public IP address from the ISP to my UDR router and let that take over. I can't seem to find a setting for this anywhere though.
The closest thing i can find was a setting called DMZ but wasn't really confident enough to turn it off and experiment with that.
Any help appreciated.
1 REPLY 1
Message 2 of 2
Re: WAN IP Passthrough with bridge mode help
Residential hubs don't have a bridge mode, nor is there a residential smart hub3.
You need to post on the business forum for advice on the business hub.
