Message 1 of 7
Wall socket & adaptor? replacement
Who would I need to contact to get a wall socket and adaptor replaced as the wires are in a pretty poor state and just about hanging on.
Any advice would be appreciated
6 REPLIES 6
Message 2 of 7
Re: Wall socket & adaptor? replacement
Assuming you are with BT it's 0800 800 150.
What adaptor do you mean?
Post a photo as it may not be BT property.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 7
FInally managed to upload a picture.
The wiring is just about hanging on in the top left of the 2
Message 4 of 7
looks like up to you to get it fixed.  if you don't know someone who can fix it then look up local paper for telecom engineer who will be able to fix it   Looks like just a normal phone extension cable
the filter will be ok
Message 5 of 7
As Imjolly has stated, that is not a bit of BT equipment. You would have to arrange your own repair or purchase a new extension cable.
Message 6 of 7
@Sausagefingers23  There's no phoneline shown connected to that filter. If that's the case, then you shouldn't need the filter.
The extension lead is very basic, sold by most hardware shops in varying lengths.
Message 7 of 7
@Carlusha
You need the filter only purely as a pstn to RJ11 adaptor as you cannot plug the router into that type of extension lead.
