Message 1 of 5
Why does my android phone say not connected to the Internet when it is but my iPhone is?
Please can anyone help with the above issue?  Thank you.
4 REPLIES 4
Message 2 of 5
Re: Why does my android phone say not connected to the Internet when it is but my iPhone is?
Hi @Deborahjayne.
Thanks for coming to the community.
Are you trying to connect your phone over WiFi or mobile data?
Which model of phone are you using?
Michael
Message 3 of 5
Hi Michael D. Thank you for your reply.
I’m trying to connect over WiFi. I’m using Samsung Galaxy A12. My Network is saying Connection Failed, although WiFi is definitely On.
Message 4 of 5
Thanks @Deborahjayne.
Have you tried to forget the WiFi network from the phone and then set it up again to see if that lets it connect?
Michael
Message 5 of 5
Michael D. Thank you for all your help. The router has reset itself and everything is working fine again.
