Message 31 of 38
Re: Wi-Fi not connecting to TV
Did you try the factory reset of the BT Hub?
If you did and it made no difference, is the BT hub you are using a second hand one?  If it is now you know why it was for sale, it is probably faulty.
Just to confirm. Are you actually paying for a BT Broadband connection and if you are why are you using a BT Business hub and not the normal BT hub that would be supplied free with the BT Broadband package.
Message 32 of 38
I posted in Samsung forum and they suggested to try connecting through hotspot. I used hotspot and it got connected straight away.
Now I don’t know where the issue is. WiFi works perfectly with all other devices but not the TV.
TV gets connected to hotspot but not the WIFI.
Are there any settings that I am missing?
Message 33 of 38
It appears to be brand new one.
Message 34 of 38
Yes, I did factory rest and it made no difference.
Message 35 of 38
What do you mean it appears to be a brand new one. Where did you get it?
Message 36 of 38
Those BT people came and installed it. It had all the packaging of brand new one so I assume it is a new one.
My landlord is the one who got this installed.
Message 37 of 38
Finally, managed to get it work.
logged into BT hub manager and opened Network for guests.
Tried guest network and it got connected.
thank you all for your help.
Message 38 of 38
That is totally weird, but glad you got it sorted.
