Message 11 of 54
Re: Wi-Fi on halo 3 do not pass 145 download
Thank you for the clarification. Let me try few tests and then I will let you know.
I am very grateful for your advice.
thanks a lot.
fulvio
Message 12 of 54
I assumed you have full fibre, the ONT is the optical modem, but if you don't have an ONT you must have a G.fast service. In which case it is not possible to bypass the hub.
Can you post a screenshot of your hub connection stats. Advanced settings > technical log > information
Message 13 of 54
Correct is a G.fast service. Not full fibre.
Message 14 of 54
See photo
Message 15 of 54
No photo
Message 16 of 54
Message 17 of 54
Message 18 of 54
Is it readable? Otherwise I try again with a new photo
Message 19 of 54
Message 20 of 54
OK, you are getting 329Mbps sync speed to the hub. It might simply be congestion in the backhaul network that is causing the slow download speed. Try running a speedtest at a quiet time of the day ( very late night or very early morning) and see if the speed changes.
