Message 1 of 5
Wi-Fi preventing apps from working on an iphone
This started today, when connected onto Wi-Fi on our iPhones, certain apps won’t work, such as WhatsApp & strava.
Have tried resetting the hub, forgetting and reconnecting network settings on the phone. We had Halo connected just over a week ago and I’m wondering whether this could be the issue?? Any help would be gratefully received. The issue is happening on all our iPhones so not an issue with one specific phone.
4 REPLIES 4
Message 2 of 5
Re: Wi-Fi preventing apps from working on an iphone
@harwood934
Welcome to this user forum for BT Retail phone and broadband customers.
Try a factory reset of the home hub,
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Its possible that the home hub has run out of internal connections, a very common issue if you have devices that are using random MAC addresses. You can probably see lots of "unknown device" entries in the home hub connections list.
A factory reset clears this list, but eventually it will happen again unless you avoid using MAC randomisation (Private Addressing ) on your home wireless connection.
This is mainly a problem with Apple devices and later Android versions.
Message 3 of 5
Thanks for your reply but unfortunately this doesn’t appear to have worked 😕
Message 4 of 5
Message 5 of 5
Hi @harwood934 I'd also recommend checking the parental controls settings in MyBT to make sure these services haven't been blocked by the filters.
Neil
