Message 1 of 2
WiFi connectivity
Hi,
My WiFi connection has been incredibly unstable for the past month.
This is very apparent when using video calls. I am close proximity to the WiFi hub and even an Ethernet cable does not improve connection.
There are no reported issues on the line and upload/ download speeds are as to be expected.
My BT hub has recently started to loose broadband connection - frequently going from blue to purple and re connecting again.
Anyone have any thoughts?
1 REPLY 1
Message 2 of 2
Re: WiFi connectivity
The first thing to try is a factory reset of the BT hub by pressing a pin into the recess button on the rear for about 20 seconds. This can often sort out problems and gives you a "clean page" to start from if that does not help.
