Message 1 of 4
WiFi disc
I have been sent my second WiFi disc. I have gone through all the instruction from the scanned qr code and the message says, “unable to connect”. It says to use the Ethernet cable, but I don’t have one! Help!
3 REPLIES 3
Message 2 of 4
Re: WiFi disc
If my memory serves me right a crucial part of the set up is connecting the disc to the router by ethernet cable.
Once that's completed you're good to go
Message 3 of 4
Re: WiFi disc
It will be a cat 5e ethernet cable.  You can get one from most supermarkets today.  About a £5 - 6 for a two meter one.
Message 4 of 4
Re: WiFi disc
BT are sending me one and admit that some set-ups do need one. Thank you 😊
