Message 11 of 26
Re: WiFi security
Don't waste your money, mate.
Perversely in this situation, one of the few good things about Wi-Fi is that it operates over short range.  Even if your security was "weak", (and as I said above, it's more of a sales encouragement/let's show the other companies up strategy than anything else), Wi-Fi range is such that someone would have to be within about 50m to get a stable enough signal to do anything useful.  WPA2 has been cracked, (years ago), but it is not easy to do which is why manufacturer's have not rushed to phase out WPA2.
Edit: Oh, and incidentally, if you replace the router you'll also need to replace all your old equipment that is WPA2 only to get any benefit, so it won't be a cheap exercise.
Message 12 of 26
Re: WiFi security
Exactly
Message 13 of 26
Re: WiFi security
The thing is that you almost certainly don't!  The majority of home routers, including those from BT, in use today use the WPA2 standard.  If you've any slightly older devices, the chances are that WPA2 is as secure as they are going to get.  If I were to enforce WPA3 here, I'd lose most of my IoT including my heating controls.
Lets say a neighbour managed to gain access to your network, they're still unlikely to be able to access anything important, unless you've servers running password free on the network.
*My network here is more complex than most, but I'm still using WPA2/WPA3 on my 3rd party router.  I can access my network and servers remotely if needed, but it's not quick, simple, or automatic.  That your router keeps out anyone trying to attack from the internet is far more important right now.
**I'm looking to toughen my IoT security, which is no easy task, is probably going to be expensive, and not for the feint hearted.
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 14 of 26
Re: WiFi security
Where this "weak security" warning may be relevant is if you are connecting to public hotspots like down the pub.
Within your own home it's highly unlikely to be a problem.  My main access point is on the upstairs landing, so it gives good coverage to the whole house.  Last time I did a proper survey round here, I needed to be right up to my back garden fence or no further than immediately across the road at the front to get a connection from outside my property. As I said before, how dangerous are your neighbours or are MI5 sitting in a van across the road all day?
Message 15 of 26
Re: WiFi security
My TP-Link GX90 has built in security. I’m set up on WPA3 but of course it’s all backward compatible with WPA2 devices. The only iot device I seem to have issues with, is my energy provider smart meter display which to be honest is garbage anyway.
Im never going to use Norton security again after the hassle it gave me on my then new laptop, such an invasive program from my personal experience. Never had any issues with Windows Defender or Bitdefender.
Message 16 of 26
Re: WiFi security
Very useful info, many thanks.
Message 17 of 26
Re: WiFi security
Hi, neighbours ok, no probs there and I use a VPN so we will have a think about the best way to go.
Many thanks.
Message 18 of 26
Re: WiFi security
Well, there again.  Wi-Fi traffic is encrypted and browser traffic is encrypted with HTTPS anyway today, so what's the point in using a VPN all the time?  All you are doing is encrypting the encryption and creating excess processing that will slow the connection down.  The only time I use a VPN is if I want to hide which country I'm in.
Message 19 of 26
Re: WiFi security
Folks confuse privacy with security.
Although why folks are happy for a third party VPN provider to have access to their data rather than their ISP is beyond me.
As you say, the only reason to use a VPN (other than a true VPN into a corporate intranet) is to change geographical location.
Message 20 of 26
Re: WiFi security
But then why would you trust your ISP with your data over a reputable VPN provider? I trust neither with my data but I still use both, though I only use my VPN provider (which I subscribe to) in certain circumstances.
