Message 21 of 26
Re: WiFi security
There is the argument that ISP's in this country have been obliged to log destinations and keep the data for 12 months since the IPA.
Message 22 of 26
Re: WiFi security
Hi, I seem to have opened a can of worms here but I am grateful for all the advice and thanks to all. Realistically I will not replace anything and will stick to the system that I have. About the VPN, I do not use it all the time just connecting when using public WiFi. I have certainly learned something so raising the issue was definitely worthwhile.
Cheers
Michael.
Message 23 of 26
Re: WiFi security
Every day is a learning day. You’ve not opened a can of worms at all. It all depends on what YOU want from your home broadband setup. ISP router = plug and play, no dramas for the majority of customers. For me, I’ll take a decent 3rd party router any day because I’ve got the control that I want over it.
Despite what others might think of my posts, there’s some excellent advice coming from other contributors here.
Message 24 of 26
Re: WiFi security
That's very true and I think that's what forums are all about and people have different opinions.
Message 25 of 26
Re: WiFi security
Personally when we are out and about on holidays, I'll have a hotspot set up on my phone, and I'll connect to the VPN server running on my router!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 26 of 26
Re: WiFi security
