Message 1 of 10
WiFi setup
Hello all. I’ve just purchased the TP-link deco m4 mesh system to enhance my WiFi capabilities, setup through the app was very straightforward and everything working as it should except I now have what appears to be 2 separate WiFi networks i.e BT and Deco which isn’t really a problem except if I need to check speeds or WiFi connection in the BT app I then have to switch between the Deco network and BT, is this normal or do I need to do anything else for it to work as one network?
9 REPLIES 9
Message 2 of 10
Re: WiFi setup
The Deco won't form a mesh with the BT hub.
Message 3 of 10
Re: WiFi setup
You need to turn off / disable wifi on your  BT smart Hub (assuming that's what you're using)
You won't be able to use the BT App to check speeds and wifi connectivity as this will now be done through the Deco App
Message 4 of 10
Re: WiFi setup
Ah ok…I brought this on the advice of an Openreach engineer who visited yesterday to check my slow internet speeds. As I said the system is working, however I now have 2 networks. So I guess I just leave everything as it is then?
Message 5 of 10
Re: WiFi setup
I would personally turn off wifi on the BT Hub.
On the Deco I'm assuming you set this up in Access Point mode as opposed to Router mode?
Is your internet FTTC or FTTP?
Message 6 of 10
Re: WiFi setup
Yes I am using BT smart hub, I’ve looked at the hub settings and can’t find where to turn off or disable WiFi in there?
Message 7 of 10
Re: WiFi setup
Not entirely sure how it is set up, I just plugged the Ethernet cable into the BT hub and followed the instructions in the Deco app. I’m on FTTC
Message 8 of 10
Re: WiFi setup
Its entirely up to you whether you leave the hub WiFi on to provide extra coverage or turn it off. If you do wish to turn it off, the setting is in advanced WiFi settings.
Message 9 of 10
Re: WiFi setup
"The Deco won't form a mesh with the BT hub."
That's correct but, AFAIK, it doesn't need to. The Deco units will form their own mesh and just need an ethernet feed from the BT hub. It's also best to turn off the WiFi that the BT hub emits to stop it interfering with the Deco system WiFi
Message 10 of 10
Re: WiFi setup
There's no need to turn it off, as long as it is on a different channel it won't interfere and will give extra coverage if required.
