Message 1 of 2
Home hub
My old laptop runs WindowsXP. Can I connect wirelessly to my new hub or do I need to use Ethernet connection?
Free live sex right now no login no cash just pick a room find naked newbie girls or ripped dudes pounding toys and wet pussies girls fingering cclit next room guy knotting hot aass the list update second by second bookmark the page bro jiizz fest non stop all nite:
1) livesexcamsxxx.org
2) sexcamscafe.com
3) sexcamshub.cc
Jump onto live sex cams watch babe ram monster dildo deep squirt like broken fire hose these webcam models dig being watched chat bar lit with begging for tiits show aassshole gape control lovense tip vibe make that cclit hum like fridge dumb fast loads daily segments
1 REPLY 1
Message 2 of 2
Re: Home hub
you should be able to connect to the new hub wifi.
if replacing an old hub then I would ,to save you effort, change the new hub SSID and wifi password to that of your existing hub then your wifi devices should connect automatically without you having to do each device manually
