Message 1 of 4
Wifi Connection
My BT Smart Hub2 has been working fine for a few years but recently strange things are happening with the wifi connection. A couple of times a day, some devices (phone, laptop) lose wifi connection but other devices continue ok (tv). Turning the router off then on resolves the issue but a few hours later it happens again. Any ideas please.
3 REPLIES 3
Message 2 of 4
Re: Wifi Connection
Try a factory reset of the hub by pressing the recessed button with a pin for about 20 seconds until the lights flash.
Message 3 of 4
Re: Wifi Connection
@Jopustiddy
Try a factory reset of the home hub,
https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Its possible that the home hub has run out of internal connections, a very common issue if you have devices that are using random MAC addresses. You can probably see lots of "unknown device" entries in the home hub connections list.
A factory reset clears this list, but eventually it will happen again unless you avoid using MAC randomisation (Private Addressing ) on your home wireless connection.
This is mainly a problem with Apple devices and later Android versions.
Message 4 of 4
Re: Wifi Connection
Just tested over the weekend and this worked, thank you very much.
