Message 1 of 8
access blocked - for the moment - why?
I have started getting the following message when I open a browser
I understand how to fix it,
but would really like to know why Access control keeps switching to OFF. I am the sole user of the machine
7 REPLIES 7
Message 2 of 8
Re: access blocked - for the moment - why?
have you got parental controls set on hub?
Message 3 of 8
No only me so no need
Message 4 of 8
then go to MYBT and check that Web Protect is not active as can be by default  if active then turn off
Message 5 of 8
I can access the web just fine. There's no BT Protection or Parental control in place
Message 6 of 8
I don't understand how you can access the web and receive that message. Have you tried a factory reset of the hub and have you checked any and all cables for intermittent connection
Message 7 of 8
Neither do I that's the whole point!
Outlook shows this
sheila23_0-1683892623855.pngBrowser shows  this
But Router has no Access Control set
Message 8 of 8
yes
