Message 1 of 5
Wifi Discs
A week ago I installed 3 wifi discs.  All was looking good with the exception that the wifi signal is still poor when I test it.  This morning when I came down all three discs had red lights.  Nothing had changed overnight, unless the cat has developed any wifi talents.  It look a lot of persuasion to get it to connect again.  Now all back and running but concerned over the reason for the sudden drop out.  Any ideas to the cause?
4 REPLIES 4
Message 2 of 5
Re: Wifi Discs
@pooh_corner
Which disks, the white BT Whole Home ones, or the black BT loaned Complete WIFI ones?
Message 3 of 5
Re: Wifi Discs
It's the black set of discs.
Message 4 of 5
Re: Wifi Discs
@pooh_corner
There was a recent software update to the Smart Hub 2 which may have caused the problem.
I am surprised that BT loaned you three discs together, as they normally only send out one at a time.
Message 5 of 5
Re: Wifi Discs
Oh they did only send 1 out at a time.  I'm still having difficulty getting a strong wifi signal.  Very disappointing to still have threir app still telling me I have poor wifi
