Message 11 of 15
Re: Wifi and Ethernet dropping daily but hub stays blue
Did you get this resolved , im having the exact same problem and keep getting passed from Pillar to post with Openreach and BT
Message 12 of 15
@Chewitson1
@darrenjhopkins  solved problem by leaving BT and going to Starlink
Message 13 of 15
Thanks I will look into it
Message 14 of 15
No I haven’t replaced that cable I will try it thanks
Message 15 of 15
My own analysis led me to belive that my IP was being blocked by BT's DNS as they thought it was being used for spam or something similar. So whilst I was technically "connected" to the internet, no URLs would resolve to an IP address. Interestingly, if I entered the IP address of a site instead of its URL then it worked fine.
