Message 21 of 23
Re: Wikipedia
Probably simply due to the reset causing a change of public IP address.
Anonymous
Not applicable
Message 22 of 23
Re: Wikipedia
@licquorice
I tried re-powering my router a few days ago to test for that.
The public IP address that I had when I first experienced the issue, after re-powering and also now after the factory reset, are all in the same range - ie the first three octets are identical, only the last three digits have been changing.
Message 23 of 23
Re: Wikipedia
So it changed.
IP addresses are logical not physical. The routing from sequential IP addresses could be totally different.
