Message 1 of 23
Wikipedia
Hi,
Not sure why but the BT router is blocking the Wikipedia web site.
I have changed browsers and retarted devices. The issue affects the directly connected PC and any phone connected by Wi-Fi. Standing in the same place and switching off wi-fi to the locla area 4g network there is no problem.... repally wifi and the issue returns.
Is there a setting on the router or My BT
Router - Home Hub 5.0 Type B
22 REPLIES 22
Message 2 of 23
Re: Wikipedia
@GarethP   No particular setting required.
Works for me. Try accessing using :  https://www.wikipedia.org/
Message 3 of 23
Re: Wikipedia
It might be being blocked by BT Web Protect. Check that BT Web Protect has not been activated on your BT account.
To do that log onto your MyBT and go to "Your Security" and check that BT Web Protect is deactivated.
Anonymous
Not applicable
Message 4 of 23
Re: Wikipedia
@GarethP
I'm on Plusnet Broadband now, but have been having exactly the same issues as you are experiencing for about 3 days now, as have a number of other Plusnet customers. Other ISPs seem to be unaffected, though I guess that those on EE might also be having issues?
https://community.plus.net/t5/Everything-else/Unable-to-Connect-to-Wikipedia-via-Plusnet-Broadband/t...
EDIT:
@CarlushaI can't get to https://www.wikipedia.org/
@gg30340    My PCs run Linux, so don't have BT Web Protect
Message 5 of 23
Re: Wikipedia
Web protect is network based, irrelevant what operating system you use.
Anonymous
Not applicable
Message 6 of 23
Re: Wikipedia
@licquorice
Sorry, I'm confusing it with the AntiVirus that BT supplied when I was a broadband customer.
Message 7 of 23
Re: Wikipedia
If you are a Plusnet customer why post here, you should be posting on the Plusnet forum where you may get help relevant to your problem.
Message 8 of 23
Re: Wikipedia
Just as an aside here; when Web-Protect blocks a site or page it posts a page that tells you that it's intervened.  You'd not see anything if it blocks data to an app that isn't just using a web container, but anything else you'll know!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 9 of 23
Re: Wikipedia
Thanks for all the responses, it is a weird puzzle, as any phone that uses the WiFi as link the web address bar has the (!) Circle for insecure, despite wiki being HTTPS.
Odd that there is a security issue that affects one site and all WiFi users.
Anonymous
Not applicable
Message 10 of 23
Re: Wikipedia
@gg30340
The link that I posted was to the thread that I started on the Plusnet forums.
I posted here because it seems to indicate that this issue is affecting BT Group customers, rather than just BT Broadband or Plusnet.
I'm an ex-BT customer, (and employee of 38 years), so occasionally still visit these forums - is that not allowed?
