Message 1 of 4
Will this brand of Ethernet cable work with my FTTP connection?
Hi,
I already have a  cable that works at 1000mbs, but it doesn't reach my current set up's position. So I'm wondering if the following long cable will work? It's up to 10gbs, so speed would be fine if it is compatible? it's 15 m, but a shorter one would work, say 5 meters, if that would improve compatibility?
Ultra Clarity Cables Ethernet Cable Cat6 15M/50ft High-Speed 10Gbps LAN Cable with Gold Plated RJ45 Connector for Router, Modem, PC, Switches, Hub, Laptop, Black,
I have a BT Halo router, with the 1000mbs connection.
Tags (2)
3 REPLIES 3
Message 2 of 4
Re: Will this brand of Ethernet cable work with my FTTP connection?
@AntRWells
Please remove the direct link to Amazon, as its not permitted on this forum.
The cable should be fine.
Anonymous
Not applicable
Message 3 of 4
The cable just needs to be cat5e or higher & less than 100m.
Message 4 of 4
Sorry didn't know about direct links, I've removed it.
Thanks for your answers, I'll get this one.
