Message 1 of 8
Wireless hdmi ???
HI
WE have a wall mounted tv and I don't want a cable running on the wall from the bt tv box to the tv is there anyway I can do this wirelessly ?
7 REPLIES 7
Message 2 of 8
Re: Wireless hdmi ???
Hi @Trendywendy1   There are plenty of products on a well known on-line retailer. The bonus is you can try and send them back for a refund if they don’t work.
Message 3 of 8
Can you advise what type of product I should be looking at ? I have no clue !!!
Thank you
Message 4 of 8
VeteranISPUser
That well known online retailer would be Amazon no doubt.
You can mention Amazon, Ebay and any other online seller, what you can not do is post links to their products. You can however name the products.
Message 5 of 8
Is it a dongle type thing I should be looking at ?
I am not technical in anyway , yes I can read reviews and decide for myself once I know what product I should be looking at
Message 6 of 8
Look for a wireless HDMI sender and receiver.
Message 7 of 8
They're not cheap, £129 upwards.
Message 8 of 8
@Trendywendy1
The HDMI receiver is going to need a mains power feed via another cable, which defeats the whole purpose of what you are trying to do.
They are really intended for cases where the set top box is across the other side of the room and the HDMI cable would be too long.
Also, you may find that content protected video and HD, is not supported. Rather a waste of money.
