Message 1 of 4
Wiring telephone line straight into rj45 or so I need a master socket in between?
hey community, I'm currently doing a rewire of a property and my client has a very old telephone connection. The signal comes in on the white and orange wire. The other 5wires red, red,red, green and black weren't connected.
My question is can I wire this straight into a rj45 socket, or do I need to go through a master socket first. And if I can connect it straight to a rj45 socket which pins do I need, I thought it was pin 3 and 6 as these are recievers but the Internet is not working.
Thanks alot.
3 REPLIES 3
Message 2 of 4
Re: Wiring telephone line straight into rj45 or so I need a master socket in between?
You need to wire it into an RJ11 socket, not an RJ45 one. RJ45 sockets are for ethernet connections, not telphones.
Message 3 of 4
Thanks for the reply, the client doesn't need telephone anymore, just ethernet! Why I thought I could do it directly?
Message 4 of 4
A phone/broadband line isn't Ethernet.
