Message 1 of 5
broadband failure
our hub starts to flash orange when we plug an iphone into an iphone charger in the same room as the hub....any ideas??
4 REPLIES 4
Message 2 of 5
Re: broadband failure
Have you tried a different charger? I really don't understand why your posting asking any ideas, if it's happening when a specific charger is used it'd point toward sit being the issue surely
Message 3 of 5
im interested to know whether this is a common problem. yes we have tried different chargers. basically our internet is very intermittant and it is driving us nuts
Message 4 of 5
this is not a common problem and you would be lucky to find another using search.  what happens if you use charger in different room maybe different ring circuit
Message 5 of 5
Assuming you are on ADSL or VDSL ( FTTC ) , these systems can be susceptible to REIN and SHINE ( search the terms if required ) but basically it’s interference from ‘faulty’ electrical devices, things like cheap Chinese Christmas tree lights , central heating pumps , dodgy fluorescent lights etc., these things can , when  switching off and on emit ‘interference’ that can causes  ADSL / VDSL to lose sync , this means that  the broadband service has to reconnect, giving a break in service ( your hub flashing orange) there was a famous example where someone with an old TV knocked out an entire village’s   broadband every time that TV was switched on…..if it’s clear when you use this charger your broadband ‘fails’ , get a different charger.
