Message 1 of 7
bt cables
need to temporarily remove bt cables screwed to fascia and reinstall later need new fascia boards can i do this myself
6 REPLIES 6
Message 2 of 7
Re: bt cables
Yes. All cables within your property are your responsibility.
Message 3 of 7
Re: bt cables
@evs51
As long as they do not come from a pole, as you would not be able to replace those yourself as they belong to Openreach.
Message 4 of 7
Re: bt cables
Crack on, your house, do as you please.
Message 5 of 7
Re: bt cables
thanks very much for reply my cables come from pole any idea of cost to get openreach
Message 7 of 7
Re: bt cables
Thanks for your reply keith
