Message 1 of 5
calls over WIFI from different providers
I am looking at moving from SKY broadband back to BT however I am not sure my SKY mobile or my wife's ID mobile will work for WIFI calling. Hers doesn't work on SKY and living in the country our Mobile signal is not good. I am stuck with my SKY mobile contact for another 12 months
Has anyone had the same issue
4 REPLIES 4
Message 2 of 5
Re: calls over WIFI from different providers
@Thomo3
I use SKY mobile with BT fibre broadband and wifi calling works just fine
Message 3 of 5
We use ID mobile in an area with no adequate mobile signal and the wifi calling works well
Message 4 of 5
Brilliant just wanted I wanted to hear
Message 5 of 5
@Thomo3  - Whether your wife is or isn't able to utilise wifi calling is down to both her phone and the chosen settings.
See if your wife's mobile is compatible here: Is my phone wifi calling compatible
