Message 1 of 4
homehub 5 signal range
Hello, just been sent the new home hub 5 that I have to plug my phone into to use the VOIP service,
Previously used a TP link AC1200 and links unit to extend range across the house.
The new home hub has poor range, how can I improve it. I assume the tp link extender is now obsolete or can it be made to work with the BT home hub?
TIA
3 REPLIES 3
Message 2 of 4
Re: homehub 5 signal range
the SH2 is the router BT issue for digital voice.  the hub 5 is an old version unless BT have a new router which never heard of yet
there are numerous posts on forum of how to use your current tplink in conjunction with BT hub
Message 3 of 4
Hi, thanks for the heads up. Sorry getting my wires crossed, It is indeed a SH". I will search for the links you mention.
cheers
Message 4 of 4
this will also help with DV
https://community.bt.com/t5/Home-phone-including-Digital/Digital-Voice-FAQs/td-p/2207485
