Message 1 of 5
how do i block cctv camera from accessing internet
hi folks, got a cheap ip camera (wireless) i want to block it from accessing the internet (stop it from calling home to china) only use it in the garden to watch wildlife,
want to block it using BT smart hub 2 firewall,  anyone know how i do it ?
can someone give me a simple step by step guide,  sorry to need spoon feeding, but my brain just doesn't work things out now
4 REPLIES 4
Message 2 of 5
Re: how do i block cctv camera from accessing internet
If you do an Internet search "How to stop IP camera accessing internet" you will find numerous answers to your question.
Message 3 of 5
i was hoping someone here had done it and could give me a spoon feed guide, that works
Message 4 of 5
Are you sure in the first place that your camera doesn't need access to the Internet to function? A lot of cameras do, for example Arlo, even if you store clips locally.
Secondly, I don't know if a BT Hub allows you to block access to specific addresses, but even if it does, you need to know what those addresses are. So, this will be unique to your camera's brand and model.
For example, I know what addresses my Arlo cameras (the brand, which, by the way, I don't recommend at all) access during normal operation. Blocking some of those make my cameras inoperative (I use a RPi so it's easier to block those on it).
There are also very few brands of cameras that don't require access to the Internet and can be used purely locally.
Yes, cheap cameras are cheap, but that's for a reason, and you should have done your research before you bought it.
Message 5 of 5
Most cameras need an internet connection to function, no one would be able to help you without the specifics of your camera ie make / model I would imagine - plus any instructions here (Spoon fed or not) would be similar to what you would find online (Minus extra effort being needed by you)
Also I'm not sure viewing birds in a back garden in the middle of November is high on any Government surveillance list, your HUBs inbuilt firewalls etc stop access being granted from any other devices on your network so I wouldn't worry about it
