Message 1 of 7
I can't seem to turn off iPv6 on my smart hub using the hub manager. It is stopping my VPN from working. How do I turn it off?
6 REPLIES 6
Message 2 of 7
Re: iPv6
You can't
Message 3 of 7
Re: iPv6
Okay. Thanks very much for your reply.
Message 4 of 7
Re: iPv6
@RL1
What VPN are you using as I run Hostspot Shield, Surfshark,Windscribe and FastestVPN - obviously not at the same time - and don't have any issues.
Having said that this is all from my Windows PC.
Message 5 of 7
Re: iPv6
Surfshark VPN l have. They told me to turn off iPv6. I find that strange, because it's been working perfectly fine for over a year and l have always had iPv6. Avira VPN cuts off my internet connection. Nord VPN seems to be working fine, however.
Message 6 of 7
Re: iPv6
Where are you actually running SurfShark from?  If it's running on a PC, have you tried just turning off IPv6 in connection properties on the device?
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 7 of 7
Re: iPv6
It's on Windows 11 laptop. I am not connected to iPv6 on it.
