Message 1 of 3
wifi passwords
should i have different wifi passwords on 2.4Ghz and 5Ghz bands
2 REPLIES 2
Message 2 of 3
Re: wifi passwords
If you have a Smart Hub2  you can't separate the bands, therefore they can't have separate passwords.
If you have a different router, its up to you whether you give them separate SSIDs and passwords.
Message 3 of 3
Re: wifi passwords
I have BT Smart Hub, thanks for your reply. That answered my question
