Message 11 of 13
Re: pfSense
Yea, I saw that this morning and looks like I will follow you.
I haven't got too complicated a setup just a few VLANs, Wireguard VPN and using pfBlockerNG.
Did it take much effort to move ?
Message 12 of 13
Re: pfSense
It took a few hours - I have three VLANS, and it was quite simple once you learn where everything is.
Instead of using unbound and setting it up similarly to PFBlockerNG, I installed Ad-Guard home which works really well and has a more user-friendly interface IMHO. Additionally, I like the fact that I can use a mobile app to check on what is being blocked and you can unblock it very easily.
I used some of the information from here to install Ad-Guard home as it is a community-built plugin
https://0x2142.com/how-to-set-up-adguard-on-opnsense/
Message 13 of 13
Re: pfSense
Thanks, will give that a go at the weekend, maybe not a good idea today as my wife is working from home 🙂
